Best way to remove rubber valve stems
Old Mar 3, 2008 | 03:52 PM
Tee-Dub's Avatar
Thumbs up Best way to remove rubber valve stems
I'm going to prep my stock wheels for powdercoating and I need help on removing the OEM rubber valve stems. Whats the best way to get them out?
Thanks.
Old Mar 3, 2008 | 03:56 PM
boyguan's Avatar
pull?
Old Mar 3, 2008 | 04:26 PM
INTJ's Avatar
Big pliers. Easiest to do from the inside.
Old Mar 3, 2008 | 04:32 PM
Tee-Dub's Avatar
Thanks, I'll give it a go. I worked on them a little bit with a small screwdriver, trying to push the rubber through the hole, but it didn't work.
Old Mar 3, 2008 | 06:48 PM
Rodney's Avatar
use a pair of dykes... cut up the inside a few times, they just fall out after that.
Old Mar 3, 2008 | 09:07 PM
AP2's Avatar
AP2
if your at home, i would suggest cutting the little gromet on the bottom first and then the main part of the valve will come right off. or go to a local tire shop and they should pull them out for free in about a minute.
Old Mar 4, 2008 | 07:50 AM
INTJ's Avatar
I do these all the time, they pull out from the inside easily. Try an old corkscrew.
Old Mar 4, 2008 | 12:44 PM
Tee-Dub's Avatar
I got two to pull out with large pliers. The other two I had to cut with a box knife and take them out. I figured they're cheap and will probably need new ones anyway when I get the tires re-mounted.
DavidNJ
May 20, 2015 11:15 AM
Mannyfresh
Sep 7, 2011 01:47 PM
GavinSSAP1
Mar 22, 2011 03:00 PM
