Blitz Type 01
Old Sep 1, 2008 | 05:57 AM
Defjux's Avatar
Thumbs up Blitz Type 01
I just ordered a set of Blitz Type 01, +45 offset all around.
I'll be running 215 tire in the front and 245 in the rear. The car is dropped an inch (the lowest my driveway is letting me go).
Any rubbing problem with this set up? I should be fine for the rear according to the stickie, but front may be a problem. If any issue, what is the best/easiest solution (fender work, camber...)?
Thank you in advance for your inputs.
Old Sep 1, 2008 | 06:35 AM
AP2's Avatar
AP2
what are the widths?
Old Sep 1, 2008 | 10:20 AM
Defjux's Avatar
17x8 and 17x9
Old Sep 1, 2008 | 10:44 AM
AP2's Avatar
AP2
the fronts should be ok but you might need to run like -3 camber to clear without rolling the fender...but i would roll them to be safe
Old Sep 1, 2008 | 10:56 AM
AP2 David's Avatar
Old Sep 1, 2008 | 03:08 PM
zbrewha863's Avatar
I used to run this exact same setup w/ -2.5 camber, didn't rub at all, and I'm dropped 1.5" on Espelirs
Old Sep 1, 2008 | 03:27 PM
breakneckS2k's Avatar
Type 01 FTMFW!!!
Old Sep 1, 2008 | 07:55 PM
RavynX's Avatar
If you just roll both front and rear fenders can you get away without any camber?
Old Sep 1, 2008 | 07:58 PM
zbrewha863's Avatar
Is that a question? Yes you can
Old Sep 1, 2008 | 11:21 PM
Mar48's Avatar
rolllllll it, much better for your tires if you aren't going to go very aggressive
