bmw wheel on s2000
Old Sep 19, 2013 | 05:17 PM
silver02s2000's Avatar
Default bmw wheel on s2000
i was curious if these were 5 x 114.3 and if somebody on this site has them on there s2000 if so provide a pic thanks !
Old Sep 19, 2013 | 08:23 PM
s2000Junky's Avatar
Their not bad looking, if you remove the center caps. Don't know if they would fit or not.
Old Sep 19, 2013 | 08:31 PM
MMisencik157's Avatar
They are likely 5x120 like ALL BMW wheels.
Old Sep 19, 2013 | 10:18 PM
Jet3010's Avatar
BMW wheels are 5x120. Those appear to be off of a 5 series as well, which means the offset is too low.
Old Sep 19, 2013 | 10:46 PM
Mikey81's Avatar
Style 32's are available on the 3, 5 and 7 series so gives you plenty of different offset options.
Just bear in mind the e39 5 series has the largest centre bore, the others are all the same I believe. Just means that spigot rings ring would need to be different sizes etc if you get them off different models
Old Sep 19, 2013 | 10:57 PM
rm cya's Avatar
Wouldn't mind seeing a set of these on an s2k. Lool awesome on 350z's
Old Sep 20, 2013 | 09:56 AM
Z3papa's Avatar
As stated, those are Style 32's which came in varying widths (7.5-9"), all 5x120, some with standard 72.4 bore unless they were off a E39 which is 74.1. I have a square set of 17x8.5 for my daily tires. Not bad wheels but they are not light either. The finish typically will delaminate a bit over time.
Old Sep 20, 2013 | 05:37 PM
sorry about the image size by the way and ive also seen some Mercedes wheels on a S2000 most of the time the alphred i think it is
s4play
Mar 1, 2006 08:16 AM
TabKhan
Mar 28, 2005 06:48 PM
djweaver
Oct 4, 2004 09:59 PM
ImportSport
Feb 16, 2004 03:55 AM
Silver S2k Guy
Apr 11, 2002 11:44 AM
