Buddyclub p1 fitment help
anybody have experience with these sizes? i have an AP1 dropped about 1" on eibach pro kit.
17x8 +45 front
17x9 +40 rear
I plan to use 215/45 front and 235/40 rear tires. The previous owner cut the rear fenders/bumper and ran 17x8.5 +42 with a 245 tire in the rear with no rubbing on a 1.5" drop. Do you think I will have issues rubbing without more fender work??
17x8 +45 front
17x9 +40 rear
I would stay with the 245/40R17 tires. You are going to be running a 1/2" wider wheels and a little lower offset which is pushing the wheels to the fenders more. You may need a little negative camber but with the fender work that has already been done that should do it.
If I can help with the tires let me know.
i may stick with the 235 since they are already on the wheels. i'm not sure the extent of the cut so i don't know if i want to risk putting on 245s quite yet with the wider rear and lower offset. will i have any problems in the front?
