camber questions
Old Jan 25, 2009 | 08:33 PM
iluvmys2000's Avatar
Default camber questions
So i've decided to add some negative camber to both my front and rear wheel. I have a my08 and i was wondering if i can go up to -3.0 on the stock camber?
Old Jan 25, 2009 | 08:43 PM
EBinVA's Avatar
Is your suspension stock? If so then no.
Old Jan 26, 2009 | 02:55 AM
s2k dre's Avatar
u should be able to! im runnin -3.5 in the rear, it doesnt matter how low u are, theres room for negative in the adjusters.
Old Jan 26, 2009 | 09:47 AM
Sinji's Avatar
the lower the car is the more camber you can get out of the stock adjusters
Old Jan 26, 2009 | 11:42 PM
Nabu's Avatar
If was under the impression that by using a stock suspension/springs combo we could only give as much as 1.7-2.0 in the front and 1.9-2.2 (?) in the rear. (numbers are not absolute but the range is somewhere around there)
Am i way off here?
Old Jan 27, 2009 | 02:55 AM
SortaRican's Avatar
Is teh stock adjustable at all?
Old Jan 27, 2009 | 03:45 PM
Nabu's Avatar
Sure it is. Adjustable double wishbones.
Old Jan 27, 2009 | 08:08 PM
THESPY's Avatar
Am i way off here?
IIRC thats if the car is at stock height. When you lower it geometry changes and you can add more camber
Old Jan 29, 2009 | 03:44 AM
Nabu's Avatar
Yup, i was refering to totaly stock settings since iluvmys2000 havent replied yet.
My comment was mostly about s2k dre's post about being able to -3.0 camber on stock suspension.
Old Jan 29, 2009 | 04:50 PM
Money2536's Avatar
Why??? Your tires will last 1/10 as long. Then you'll end up buying crappy tires negating any benefit of running slight more camber.
