Can I even fit these?
I hope this helps ya out. Here is dimensions that will give a ball park idea.
Rim dimensions that would work out:
(Not having to roll fenders)
For the front:
6.5” to 7.5” wide wheel: 205 tires: +43 offset minimum
7.0” to 8.0” wide wheel: 215 tires: +48 offset minimum
7.0” to 8.0” wide wheel: 225 tires: +53 offset minimum
7.5” to 8.5” wide wheel: 235 tires: +58 offset minimum
7.5” to 8.5” wide wheel: 245 tires: +63 offset minimum
For the rear:
7.5” to 8.5” wide wheel: 235 tires: +40 offset minimum
7.5” to 9.0” wide wheel: 245 tires: +45 offset minimum
8.0” to 9.5” wide wheel: 255 tires: +50 offset minimum
8.5” to 9.5” wide wheel: 265 tires: +55 offset minimum
9.0” to 10.0” wide wheel: 275 tires: +60 offset minimum
9.0” to 10.0” wide wheel: 285 tires: +65 offset minimum
For the front:
For the rear:
