Can I run same Aspect Ratio front & back?
I'd suggest doing the math to figure the sidewall heights. The ratio by itself doesn't mean much.
Keep in mind that sidewall heights are the same when you're non-staggered.
Originally Posted by Lex,Oct 1 2010, 09:36 AM
I noticed a lot of people that track there cars run the same aspect ratio on all four but those folks are also usually non-staggered where as I am going with a staggered setup so I don't know if this will work or not.
Sidewall height is a percentage of tread width and not a fixed number. For example, 35% of 255 will obviously be bigger than 35% of 225. You would want a 225/40 in front to match the 255/35 rear. Obviously if you are running same size width then you want the sidewall ratio the same.
Nothing wrong with running smaller dia. tires in the front. Just know it will change the balance of the car and you may need to do some tuning to get the balance back.
Smaller dia. tires in the front will increase the cars rake, and in most cases increase oversteer. (may be a bad idea on a stock AP1)
Good point about the ABS.
I have not had any trouble running 274/40 17 with 245/40 17 A6 Hoosiers on an 2004 and 2008 S2000. At least the AP2's seem to handle different size tires well, but you are right that it could cause problems.
