can you run this size and offset?
Old Jan 9, 2008 | 04:36 PM
ego's Avatar
ego
Default can you run this size and offset?
17x8+35 17x9+35 I came across some wheels in this size and was sure if it would work. Any help on this
Old Jan 9, 2008 | 06:26 PM
Flite's Avatar
No.
Some people will tell you "sure, it's fine. Just roll your fenders and run a lot of camber". Don't listen to them.
Old Jan 9, 2008 | 07:09 PM
silentdancer's Avatar
Originally Posted by Flite,Jan 9 2008, 07:26 PM
No.
lol do you have experience with this offset?
this is 17x8+25 front, 17x9+35 rear.
This is 17x8+35 front, 17x9+35 with hankook rs2 in stock ap2 tire sizes.
Old Jan 9, 2008 | 07:11 PM
Flite's Avatar
You just proved my point.... they don't fit.
Old Jan 9, 2008 | 07:12 PM
some people dont like to run 60 offsets
Old Jan 9, 2008 | 07:14 PM
here is 17x8.5+41 17x9.5+41 which is more aggressive than the original poster asked for
does this not fit as well?
Old Jan 9, 2008 | 07:17 PM
Flite's Avatar
I posted an offset in this thread? Al I said is that a +35 offset on a 9" wheel isn't going to fit right.
What tire sizes are on those wheels up there? What camber? What kind of fender work if any?
Old Jan 9, 2008 | 07:18 PM
215/45, 245/40 with room to run 225/255
camber was around -2 front, -3 rear. just rollled fenders
Old Jan 9, 2008 | 07:27 PM
Flite's Avatar
Again, you proved my point. That car is running out of spec alignment, with stretched tires, and rolled fenders. The wheels DO NOT fit the car properly.
Don't get me wrong, the car looks good. That's not a proper fitting wheel though. By your logic you could say "sure, you can run an 18x11 +25 wheel on he car, you're just going to have to buy fender flares or a widebody kit, run stretched tires, cut your stock fenders out, and run some camber". Sure the wheels will fit on the car. But they don't fit properly.
For a wheel to fit the car properly, it should be able to clear a stock body car with the steering at full deflection and full suspension stroke with factory spec alignment. I understand making a compromise for looks (I doubt my wheels fit THAT properly). But, the wheels you posted are a bit extreme for me and I wouldn't recommend someone who's not serious into the whole "hella-flush" wheel craze to buy them. It's going to compromise the driving of the car too much.
Old Jan 9, 2008 | 07:29 PM
Don't get me wrong, the car looks good. That's not a proper fitting wheel though. By your logic you could say "sure, you can run an 18x11 +25 wheel on he car, you're just going to have to buy fender flares or a widebody kit, run stretched tires, cut your stock fenders out, and run some camber. Sure the wheels will fit on the car. But they don't fit properly.
For a wheel to fit the car properly, it should be able to clear a stock body car with the steering at full deflection and full suspension stroke with factory spec alignment. I understand making a compromise for looks (I doubt my wheels fit THAT properly). But, the wheels you posted are a bit extreme for me and I would recommend someone who's not serious into the whole "hella-flush" wheel craze to buy them. It's going to compromise the driving of the car too much.
i understand where you are coming from, just wanted to give the guy some hope that these will fit with some minor mods. in case he really wants to run the wheels
