ce28
Wheel Diameter (Inches) - 8"
Wheel Width (Inches) - 17"
PCD Bolt Pattern - 5x100 & 5x114 (dual drill)
Offset - 48mm
stock ap2 is 17"x8.5 so i dont know if the 8 will look good.
and in the bolt pattern what does 5x100 mean?
Offset - 48mm
stock ap2 is 17x7 front 17x8.5 rear... the reason you stagger is for the wider tires in the rear... although you can do stagger tires on non staggered wheels but not really recommended
this is a bolt pattern that 93-04 subaru impreza uses most commonly
stantaur
Jan 8, 2008 04:27 AM
