CE28 Fitment on AP1
I've done some searching and am still new to really understanding tire fitment. I am looking at getting a set of CE28 10 spokes for my AP1. I am going to be lowered on coilovers, but not slammed or anything. I was looking at running a 17" X 7.5" with a +43 offset. The rear is 17" x 9" witha +40. Will this fit with just rolling fenders? Or will a pull be needed as well. I want a slightly aggressive look, but nothing insane. The availability is:
Thanks for any help guys.
You need a wider rim up front. That wheel combo is going to be about 20mm difference, making the fronts quite sunk in looking compared to the rear. A more even look to the rear would be the 8.5 +50 up front. This will let you run a 235/255 nicely. Roll the fenders in back to fit. Up front should be done to be safe. The 9.5 +40 is also a good fitment option for the rear. It will be 6.5mm more aggressive then the 9", but give you a little better sidewall profile with a 255. You have a few different good fitting options with those wheels. Just depends on if you want to roll fenders and what size tires you want to run. I always assume more tire is best.
Everything I stated above is in respect to not needing to pull fenders for fitment. Just rolling and proper alignment.
JoeyBalls
Oct 2, 2013 12:23 AM
