confused about SO2s
I read the sticky at the top of the page and it said that the OEM tires are bigger than what they say and that we should get 245s in the rears if the tires are non OEM. Is there a nonOEM 225 version of the SO2s? Like, if i go to my local tire shop and purchase a pair of 225/50/16 SO2s will they be too small? Or should i get some 245 SO2s for the rear? Is there a difference between an OEM 225/50/16 S02 and a 225/50/16 SO2 from a local tire shop?
Originally posted by CyrusA Is there a nonOEM 225 version of the SO2s? Like, if i go to my local tire shop and purchase a pair of 225/50/16 SO2s will they be too small?
If you take a look at the tread pattern, you'll notice that the front and rear S-02 for our cars has a rather different pattern, some of the blocks are bigger or smaller, almost at random. I'm guessing this is intentional for this special tyre type.
Suggest you ask them for the S-02 with W speed rating. All others (ZR rated) aren't the special tyre for the car.
W (270kmh) should be enough unless you're pushing some major boost!
///Robin
///Robin
Rusler Firbrand
Jan 12, 2004 09:00 AM
