Confusion! Fitment Size Help
Old Mar 15, 2011 | 05:16 PM
BrianThePradiG's Avatar
Default Confusion! Fitment Size Help
I have read the forums and the fitments and everything has me confused, still. (I have tried searching for the answer but everything is still unclear). I would just like an answer.
For an Ap1, Would 18x8 +40 (fronts) and 18x9 +45 (rears) fit without fender beings rolled / pulled?
If that doesnt fit, what sizing would fit, and what would YOU recommend?
itll be on coils in the future, but wheels are coming first.
Old Mar 15, 2011 | 09:14 PM
1nate7's Avatar
No. There are a lot of factors, but generally speaking you need +50 or higher if you don't want to do any fender work. If you want a fitment even close to flush then you need to roll the fenders, no way around it.
Old Mar 16, 2011 | 07:04 AM
ertbll's Avatar
just roll your fenders doo it, doo it!!!!lol
Old Mar 16, 2011 | 11:21 PM
but will 18x8 + 35 fronts and 18x9 +40 rears fit an s2k? or would going 17x8+35 and 17x9+40 be better since i could go lower?
Old Mar 17, 2011 | 12:57 AM
HonCBRf2's Avatar
Just think of it this way, anything below +45/+50 will need fender work, especially if you are lowered. the lower you go on the offset, the more fender work and negative camber you'll need...these cars weren't designed to have a low offset.
Old Mar 17, 2011 | 05:45 AM
Jim@tirerack's Avatar
Former Sponsor
A lot can be done with narrower tires and negative camber but the offsets you mention are going to need some finder work as well.
Old Mar 17, 2011 | 10:24 AM
yeah imma def roll the fenders, but will 18x8 + 35 fronts and 18x9 +40 rears fit an s2k? or would going 17x8+35 and 17x9+40 be better since i could go lower? and would i have to run negative cambers for the wheels?
sorry im new to the whole wheel scence, looking to expand my knowledge
Old Mar 17, 2011 | 11:36 AM
1nate7's Avatar
Yes, WITH rolled fenders. Assuming you run proper stock size diameter tires, there will be no difference between the 18" and 17" setup as far as fender clearance. The stock alignment already has "negative camber", it's just matter of how much you want for the handling/tire wear tradeoff. I'd suggest just reading everything you can before buying anything.
iDomN8U
Jul 16, 2012 08:36 AM
lreyn003
Jun 17, 2011 06:56 PM
JLiz_F22C
Apr 5, 2011 01:29 PM
azride1983
Sep 18, 2009 04:42 PM
vtec88
May 11, 2009 12:11 PM
