Would these wheels fit?
Old Apr 20, 2009 | 11:10 AM
vtec88's Avatar
Default Would these wheels fit?
I searched already but i want to double check if anyone has had first hand experience with this fitment. Anyways the specs are:
super advans
16x7 +35 offset on 205/45/16
16x8 +38 offset on 225/45/16
this would be on a 03 ap1 with eibach prokit (about 1" drop)
would i have issues with rubbing with rolled rear fenders?
thanks for any input.
Old Apr 20, 2009 | 12:23 PM
Jim@tirerack's Avatar
Former Sponsor
I would say you are going to need to do some modification to make those work. Fender lip roll and negative camber along with the narrower tires.
Old Apr 22, 2009 | 11:44 AM
vtec88's Avatar
the previous owner had my rear fenders cut to fit a 17x8.5 +42mm wheel with a 245/40 tire with no rubbing issues. anyone have any personal experiences with sizes like this? i found a couple old threads but they are always 50/50 on this topic.
Old May 4, 2009 | 02:48 PM
vtec88's Avatar
anybody?
Old May 4, 2009 | 02:59 PM
silentdancer's Avatar
that will fit, change out the front tires to a 55 series though
Old May 6, 2009 | 01:03 PM
BSeriouS's Avatar
You will rub if you do not mod the fenders. 55 series up front will be best to get the same rotational diameter as your stocks. If not your speed to speedometer ratio will be off
Old May 11, 2009 | 12:11 PM
vtec88's Avatar
you think the fronts need fender work as well? the rears have been cut already so i'm not worried about that
blkswan
May 30, 2018 05:37 PM
pappi16
Dec 20, 2012 07:03 AM
BrianThePradiG
Mar 17, 2011 11:36 AM
Gatsbee13
Apr 24, 2007 06:43 PM
phizzak.s2k
Nov 13, 2006 03:31 PM
