custom offset on 18's
Old Nov 15, 2007 | 01:26 PM
andykim7's Avatar
Originally Posted by Jim@tirerack,Nov 14 2007, 08:39 AM
The higher the offset the more room you will have for the bigger tires. In the 18X9.5 I would look around 63mm and for the front around 50mm offset.
So would it be possible to run a 265 rear with that offset and width?
Old Nov 15, 2007 | 05:18 PM
silentdancer's Avatar
yes with your rolled fenders it will fit easy
Old Nov 15, 2007 | 06:29 PM
jdmfool's Avatar
can i fit the work xd9 18x9 +20 and 18x8 +35. i know i have to do alot of fender flaring i just love aggressive wheels
Old Nov 15, 2007 | 07:39 PM
Enthralled's Avatar
could i go with the AP2 OEM offsets?(+55 fronts, +65 rears) I had no rubbing when i ran my stockies.
Old Nov 16, 2007 | 07:02 AM
Sinji's Avatar
with that offset on a x8 and x9 you should be perfectly fine
Old Nov 16, 2007 | 07:03 AM
Sinji's Avatar
no, you need at least a rear fenderflare to fit the rear properly. the fronts you might be able to go with
Old Nov 17, 2007 | 08:01 AM
pinoyk20's Avatar
Originally Posted by Sinji,Nov 13 2007, 03:33 PM
18x8+48 and 18x9+55. also depends on tire size
what type of rims are with this specs??? and what tire size will be perfect??? thanks!!!
DFWs2k
Mar 24, 2006 05:01 AM
bigpurp
Jun 18, 2004 02:59 PM
AndyS2
Oct 26, 2003 07:12 PM
whiteGoKart39
Apr 11, 2003 10:47 AM
