Do the lug nuts you use scrap the paint off ?
I am running SSR type C rims and it is scratching the paint off where the lug nuts meet the wheel?? anyone else having this problem with their rims?
You are most likely using the wrong kind of lugnuts. The taper may not be compatable with the rim hole. This is quite evident whenever someone uses OEM lugnuts on, for example, Volk CE rims. Without the proper lugnuts, the paint takes a beating around the holes.
Originally Posted by lamvu,Jan 20 2006, 11:30 PM
I got some after market lug nuts, do you have a picture of the correct lug nuts used?
Originally Posted by spa-zz,Jan 21 2006, 08:49 PM
Doesn't the lug cover the area when it's in place?
Originally Posted by rijowysock,Jan 21 2006, 09:11 AM
the only ones that dont scrape are the new ones evasive sells that have bearings in em,
other than that make sure your using the rigt nuts..
round end or 60* tapered
Originally Posted by xviper,Jan 21 2006, 10:19 PM
Yes, but the paint goes right down into the bevelled part of the hole. If the taper of the lugnut doesn't match the taper of the hole, undue pressure is placed on the walls of the hole. The paint chips and in time, begins to peel back from the hole. Certainly, the area is covered, but the fact the paint chipped is an indication that the wrong lugnut has been used.
So I don't know if chipping paint could indicate that a wrong lug was definitely used.
Originally Posted by spa-zz,Jan 22 2006, 09:39 AM
Well I used to have SSR Comps (type C is the same wheel, right?) on my E46 M3, and the paint in the conical portion chipped off under the lug after only a few mount/dismount cycles (proper lugs were used). I figured I could call that normal considering the 5 tons of force a lug places on a wheel over a very small area. However when the lugs were on, you could not see that area and the rest of the paint was fine.
