Does anyone run a 275/40/17 square setup ?
Old Jun 19, 2014 | 06:25 PM
riceball777's Avatar
Default Does anyone run a 275/40/17 square setup ?
Does anyone run a 275/40/17 square setup ? If so how do the front fit with stock rolled fenders. Also what size and offset rim do you run?
Old Jun 19, 2014 | 08:11 PM
s2000Junky's Avatar
How do they fit? Poorly, you won't find any examples, unless the front fenders look like they have seen 2 campaigns in Nam.
Old Jun 19, 2014 | 08:46 PM
Manga_Spawn's Avatar
Site Moderator
Even rolled you aren't fitting that tire up front. With that wide of a tire you will rub the inside with an offset and width that would fit within the oem fender. If you had downforce fronts then you could probably fit them.
Old Jun 20, 2014 | 10:01 PM
s2000Junky's Avatar
If you stay at stock ride height and pinch it on a 7" rim you might that would be sweet!
Old Jun 22, 2014 | 09:19 AM
Site Moderator
Even then the oem suspension will probably be in the way. Coilovers are much smaller so the wheel has more room to move in there.
Old Jun 22, 2014 | 08:57 PM
s2000Junky's Avatar
I was being more satirical, but regardless, your absolutely correct.
Old Jun 23, 2014 | 05:00 AM
afzan's Avatar
Don't forget the taller tire will cause issues as well. You might have issues with the headlight brackets hitting the tires
Old Jul 5, 2014 | 07:14 PM
99SH's Avatar
I'm running a 17x10 275/40 square setup on mine. Front offset is +57 and running ASM style fenders. Fits with no issues including clearance against suspension components. I'm also running a steering rack spacer.
Old Jul 6, 2014 | 12:27 AM
s2000Junky's Avatar
Stock rolled fenders was the question, not aftermarket wide fenders.
hoobastnk90
May 18, 2017 07:26 PM
pappi16
Dec 9, 2012 11:53 AM
sj7
Dec 26, 2011 11:02 PM
kidtofuu
Feb 14, 2011 08:01 PM
buzz944
Jul 6, 2009 10:33 PM
