Enkei Help
Old Apr 8, 2010 | 12:27 PM
s2000freak23's Avatar
Default Enkei Help
My car is under a APR widebody process. The rims I decided to get is Enkei rpf1. One of my friends went to see the APR car in person and he said that they are running a conservative setup. Their specs are 18x9 front and 18x10 in rear. Do you guys think it would be a problem if I went with 18x9.5 front and 18.10.5 in rear. My body guy cut the stock fenders in the rear that was recommended by APR.
Old Apr 8, 2010 | 12:33 PM
clarkster009's Avatar
Well, you have seen the APR car right? What do you think of the look? Also, you can keep those rim sizes and get a lower offset, or you can get the 9.5s and 10.5s and get a higher offset. I thought I remembered the guy saying the APR body lets you use 350z wheel specs.
Old Apr 8, 2010 | 12:34 PM
But don't get those wheels!! They are so played out on the S2000 even though the sizes will be better. Is it just that you can't afford Volks or something? Cause I know the Enkeis are moderately priced.
Old Apr 8, 2010 | 09:12 PM
JDMQuip's Avatar
Just as played out as Volks, Work, Advan's on the S2000. Let the man do what he wants to do.
Old Apr 8, 2010 | 09:15 PM
s2k dre's Avatar
Yea theres no such thing as a rare wheel anymore. Just because u see them on the net dont mean ur gonna find them on the street.
Old Apr 9, 2010 | 01:19 PM
Everything is almost played out now its all about taste.
I'm sry for the following noob question but if i get the 9.5 and 10.5 specs I cant go with the lowest offset available?
Old Apr 9, 2010 | 02:11 PM
1nate7's Avatar
The problem is that most of us don't know how much extra clearance the widebody will allow. If you could find that information out then we could make a recommendation. Most 350Z's run 9.5/10.5 +15. As for being played out, get what you want but the widebody does open up a lot more options in low offset wheels that don't work on a stock body.
Old Apr 9, 2010 | 03:42 PM
Thanks for the info. I will try to get the information.
Old Apr 9, 2010 | 07:55 PM
bakalag's Avatar
not meaning to thread jack but I have an enkei rpf1 question too and too many enkei threads popping up would be bad
I'm planning on getting 17x7 +45 front with 215 tire
17x8 +45 with 255 tire
17x9 +45 with 255 tire
I'm on stock height and alignment so would it still rub?
How would the handling be if I have 17x7 and 17x8 combination VS the 17x7 and 17x9 combination?
the tires I'll be using are 215/45/17 fronts and 255/40/17 rears (already have them)
thanks
Old Apr 9, 2010 | 08:40 PM
Chow-bot's Avatar
^have you not seen the RPF1 thread?
