Extended wheel stud question
Old Jun 11, 2010 | 02:46 PM
prorcracer87's Avatar
Default Extended wheel stud question
I just bought a set of ARP extended wheel studs and i found a topic on this forum saying that wheel bearings dont need to be replaced.
I brought it over to my mechanic to get them done, and he said i needed them. Since hes removing the hub, the bearing is going to separate into 2 pieces. If he installs it back as 2 different pieces, theres a chance the hub will fly off the car with the wheel.
Fill me in on this...please!
Old Jun 12, 2010 | 02:16 PM
nickp's Avatar
you shouldnt have to replace the bearings. ill be doing extended studs in the rear shortly and will have a defonate answer
Old Jun 12, 2010 | 08:13 PM
PaddyMcP's Avatar
You do not have to.
Old Jun 12, 2010 | 09:10 PM
gCHOW's Avatar
x2.
i dont believe you have to. i will be getting extended lugs on my car (front) soon and will give you a for sure answer. but right now, looking at the helms manual you do not.
Old Jun 13, 2010 | 12:33 AM
Voodoo_S2K's Avatar
When you remove the hub to install the new studs, you will separate the bearing. This bearing was not meant to be separate. It is possible to reinstall it, but I personally would not.
Old Jun 13, 2010 | 05:14 AM
ktr6's Avatar
I agree. Just got done doing the same thing for my track only S2000. I went ahead and replaced the bearings while I was there.
Old Jun 13, 2010 | 05:15 AM
1tsxer's Avatar
^+1
Old Jun 14, 2010 | 08:09 AM
orangebarius's Avatar
yes the bearings do come apart. you can put them back together or just replace them. depends what you feel comfortable doing. i have seen both ways done on local s2ks with no problems.
s2nasty03
Jul 5, 2015 10:23 PM
chino101
Aug 18, 2011 08:14 AM
S2k.berto
Jun 21, 2011 09:07 AM
Ro_Ja Boy
Mar 12, 2011 07:05 AM
Quivers
Jun 4, 2006 06:25 PM
