extensive wear down the middle of the tire...
My rear tires that are getting extensive wear down the middle of the tread. They were inflated to 36lbs. I even lowered them to 34lbs to see if that would help...but nothing.
Tire specs:
Bstone S-03
255/40 - 17
I'm guessing that PSI is not too much for the tire, but I could be wrong. Is there anything that could've contributed to that? Alignment? I need new tires soon, so i would like this question answered before throwing on new shoes.
Thanks,
chikai
Tire specs:
Bstone S-03
255/40 - 17
Thanks,
chikai
I am seeing the same problem with my Pirellis (265x35 18). I've checked the pressures routinely (32psi) and still wear down the center. I've been getting around 8000 per set on these sneakers. Grippy as hell, but I swear I can hear the rubber wearing off.
Originally Posted by SIIK2NR,Sep 16 2005, 10:36 AM
Launching can cause center wear on tires....
kind of a late post... but could it be possible if you oversize the tire a little bit in respect to rim width, a slight tire pince could cause wear down the middle? would deflating the tire a little help?
Possibly.
