Falken Azenis RT-615
I have a set of CE28N's on order and was going to try a set of the new Falken RT-615's.
I have Falken's on two other cars and really like em, was just wondering if anyone here has tried them on an S2000 and if so how they handle?
Thanks in advance,
Bob
Thanks in advance,
Bob
The car isn't lowered and the clearance difference on the inside front is only 1mm (.039) less than stock, the outside of the front wheel will be 11mm (.433) farther out than stock.
The rear clearance will be 4mm (.157") less and the outside of the rear wheel will be 8mm (.315) farther out than the stockers.
I'm hopin' it doesn't rub, seems like there are other members running this setup without rubbing.
Thanks for the feedback, the tire shop I deal with just put a set of the RT-615's on a Subaru STi and he said they worked well.
I'll let you know what the results are once I get em' mounted up.
Bob
Bob
