Fender Rubbing
Old Jun 18, 2015 | 11:34 AM
garykoo's Avatar
Default Fender Rubbing
So i recently went for a wider front setup and the wheels seem to be rubbing the fenders slightly and caused the paint to crack. Im running 17x9 +29 offset with 235 tires. Car is dropped about 1.75-2 inches and the camber is maxed out at -2.3 degrees with toe and caster at oem specs. I dont really want to raise the car or increase the camber too much. Any suggestions?
Old Jun 18, 2015 | 11:37 AM
Manga_Spawn's Avatar
Site Moderator
No kidding it is rubbing. That is way to aggressive an offset for the front. Are the fronts rolled? Last option is to pull the hell out of the fenders.
Old Jun 18, 2015 | 03:23 PM
d1000rr's Avatar
Can you post a picture? I honestly have no idea how that even fits...
Old Jun 19, 2015 | 06:50 AM
tkokay's Avatar
Im also interested in a picture of this. are you running the correct circumference tire?
Old Jun 19, 2015 | 07:30 AM
RedCelica's Avatar
Yeah +29 is WAY too aggressive unless you're planning on pulling the fenders.
Old Jun 19, 2015 | 07:36 AM
DrakeValle's Avatar
A kid local to me had 17x9+20 square. Never saw it in person, but I can only image what it looked like. He already had bacon fenders from his previous, less aggressive setup.
Old Jun 19, 2015 | 07:37 AM
RedCelica's Avatar
those poor fenders...the S doesn't deserve to be mauled like a hiker in the woods covered in peanut butter just to make a set of shit wheels fit.
Old Jun 19, 2015 | 08:26 AM
Site Moderator
The tire has nothing to do with it with this setup. The offset is to low. Even if he had a 215 it would rub under the right conditions due to the width and offset is way to aggressive.
Old Jun 19, 2015 | 09:14 AM
tkokay's Avatar
But if the tire isnt as tall then there is less to come in contact with the fender. Its only a small gain for him but could be the reason that hes even able to drive on it at this point. Just by his blurb above it sounds liek the wheels are close to fitting if hes just rubbing. *waits for picture of the fenders falling into the grooves of the tire*
Old Jun 19, 2015 | 10:05 AM
Site Moderator
I have 17x9 +43 with a 245 and -2.5 front camber and my fronts are pulled. That barely fit. A 17x9 +29 does not fit and will rub even with the 235. The 235 is an odd tire size in that it is either slightly smaller than oem with the 235/40/17 or slightly taller than stock with the 235/45/17. Either way if the wheel was a offset that fit it wouldn't be rubbing. It is easily 11mm to aggressive especially for the front.
