Fender Rubbing
Old Jun 20, 2015 | 06:04 PM
garykoo's Avatar
My bad guys i totally forgot to mention they are on downforce fronts right now i think the rubbing is only happening when i go in and out of drive ways cause the tires seem very clean and doesn't seem to be rubbing when I'm cornering or just driving. I don't hear any rubbing either.
Old Jun 20, 2015 | 06:07 PM
garykoo's Avatar
So here are the pics of the rub
Old Jun 22, 2015 | 08:44 AM
Manga_Spawn's Avatar
Site Moderator
Ah important piece of info there. Yeah it looks like you are rubbing when the wheel is turned. Not good and you are making me worry about what will happen when I get my downforce fenders done. There really isn't many options here. What suspension are you on? You could raise it a little bit or go with a stiffer spring. That may help. A little more camber may also help but won't really do much as it is happening when the wheel is turned.
Old Jun 22, 2015 | 08:58 AM
DrakeValle's Avatar
Yeah isn't rubbing when turning almost impossible to avoid without raising/stiffening suspension?
I mean, I rubbed on stock wheels/tires while turning.. I was lowered about a finger gap. The suspension was very rarely under enough load to come close to the fender while turning during normal or even spirited drives. The only time I had an issue was in driveways.
Old Jun 22, 2015 | 09:18 AM
Site Moderator
Yeah its not an easy problem to solve.
Old Jun 22, 2015 | 10:23 AM
garykoo's Avatar
Yea it seems its only during full locks and steep drive ways that it rubs. I didnt expect it to rub since i bought the wheels off another member who ran the exact setup. Im on tein monoflexes and the springs are 11k/10k so i dont think i wanna go stiffer than that for a street car. Im thinking of adding an upper ball joint and dial in a little bit more camber and see how things go. I really dont want to raise the car since this height doesnt cause any scraping and the car sits perfectly right now haha. Another option i thought of doing is to roll the fenders slightly, but im not sure if that will work since the fender seems to be fibreglass and not metal.
Old Jun 22, 2015 | 10:27 AM
garykoo's Avatar
Also the fenders did not fit as well as what i was told. The driver side fender's edge where it connects to the headlight doesnt line up perfectly. This could be because my driver side was damaged in an accident and may have messed up the allignment of the panels. But i thought i'd let you know. There was also a bit of trimming done to it as well but im not exactly sure where haha.
Old Jun 22, 2015 | 11:05 AM
s2000Junky's Avatar
You just have to alter how you enter/exit off camber driveways. You can’t just crank the car over with the wheels at full lock and inter a driveway like a normal stock DD. Always turn before the driveway and then straiten wheels out and go over with car at an angle. I’ve been driving this car this way for years and don’t even think about it anymore, just do it. You will get to know what kind of steering lock you can/cant get away with eventually and hope you don’t cause too much damage during the process.
Old Jun 22, 2015 | 01:20 PM
garykoo's Avatar
I actually do that too but i guess i need to watch how much i turn during some situations, but most of the time i think i do exactly what you do right now haha
thomsbrain
Mar 25, 2017 12:26 AM
blkmkIII
Mar 23, 2012 08:07 AM
David_T
Sep 7, 2008 04:09 PM
racecar fun
Aug 29, 2008 11:35 PM
