Fitment
hey guys i have a 2000 honda prelude base.
and i have stock acura tls wheels cause i got 19's for them.
i was wondering if anyone knew if i could just swap out the tls wheels and tires on the prelude without any problems?
thanks
Report this post to a moderator
thanks
I believe you could.
You might run into brake caliper hitting the inside spoke of tl rims though. But there's only one way to find out!
I know it's not the same, but I've put s2k rims on my TL before...
http://www.socal28.com
First off the the S2K wheels do not have enough load capacity for the Acura. I think the wheels will fit but the offset is a little high on the TL-S. You would need to check the inside clearance.
If I can help let me know.
Thank you
Jim 877-522-8473-364
Thank you
