Fitment
Old Jan 19, 2007 | 03:05 PM
04s2k619's Avatar
Default Fitment
18" Volk Sf-Challenge in Gold 18x8 +48 all four
I want to buy these wheels from a member here, but with my lack of knowledge, I wouldn't know if these wheels will work fine for the s2k or not? Is the offset ok? The rear wheel of the s2k is wider then the front, this member is selling all 4 wheels the same size...is this going to be a problem?
Thanks for any input.
Old Jan 19, 2007 | 03:21 PM
bunz559's Avatar
hahaha... i was readin ur other thread... wow!! but this is something new to me also, i'd like to know if all four wheels with the same offset would work also!! and what size tires would go ok with these issues.
scott
Old Jan 19, 2007 | 03:22 PM
04s2k619's Avatar
LOL! I know, it's a little weird with all 4 wheels the same size which is why I'm worried....
TO THE OTHER THREAD
Old Jan 19, 2007 | 04:19 PM
BSeriouS's Avatar
yes this set up will work. Its not ideal to some eyes because there non staggered, but nothing but a staggered tire set up won't cure it
245/215 combo is Perfect. Although, As i said, some will look down on this, but its your choice
Old Jan 20, 2007 | 05:47 AM
CaptainMike's Avatar
I'm one of those people who wouldn't do it. The Falken 512's (mentioned in your other thread) aren't really very good tires either, do you plan on running them year round? What is your location? If I recall correctly (from the other thread) your OD's (Outside Diameters) will be different as well with 245 40's and 225 40's. Also I'm fairly sure those rear sizes will rub, unless some corrective action is taken (such as fender rolling, extreme suspension setup, etc.)
Can you do it?
Yes, of course you can, it's your car.
Is it ideal or close to ideal for handling and safety?
Nope.
Good luck,
Mike
Old Jan 20, 2007 | 09:49 AM
silentdancer's Avatar
those will fit with a 245 in the rear with no rubbing, but i would not recommend this set up either, just wait for the right sized set to come up
TJ
Old Jan 20, 2007 | 05:30 PM
i2ichal2d's Avatar
if im running non staggered, i would run x9's all around!!! and same tires all around!! it really neutralizes the car
Old Jan 21, 2007 | 03:23 PM
vietboyjl's Avatar
Can you do it?
Nope.
Good luck,
Mike
I'm located in San Diego California. The s2k isn't my daily driver. I drive the car only a few times a month. Right now the car has Tein Flex suspension on it.
What is wrong with Falken 512's?
Old Jan 21, 2007 | 03:28 PM
the 512's are kinda crappy IMO.
Old Jan 21, 2007 | 03:43 PM
Not very grippy compared to a lot of other options out there.
