Fitment options, which would be easiest ?
Old Sep 5, 2017 | 02:05 AM
Sipha's Avatar
Default Fitment options, which would be easiest ?
Hi guys,
Just doing some rough calculations for my new split rims, I have 2 options I can go with depending on how I use the lips.
Which one of these options would potentially be easier to fit ?
17x8.5 +35 (6.5" barrel, 2" lip) Front
17x9.5" +35 (7" barrel, 2.5" lip) Rear
OR
17x9 +47 (7” barrel, 2” lip) Front
17x9 +22 (6.5” barrel, 2.5” lip) Rear
Thanks
Old Sep 5, 2017 | 04:43 AM
Sipha's Avatar
Rolled lips front and rear, Rear fender tabs relocated.
Old Sep 5, 2017 | 09:30 AM
Manga_Spawn's Avatar
Site Moderator
Niether are a good fit. The first option is aggressive all the way around while the second option is super aggressive the in the rear while being pretty conservative in the front. I guess the one that would look the most uniform is the first option but it still isn't going to fit very well.
Old Sep 5, 2017 | 10:58 AM
Sipha's Avatar
Thanks, do you think some negative camber and the roll would be enough ?
Old Sep 5, 2017 | 11:08 AM
ZDan's Avatar
Limited to those wheel size options, I would go with 17x9 +47 all around and 235/40-17 fronts with 245 or 255/40-17 rears.
Negative camber within reason (-3 degrees) isn't terrible for tire life as long as toe is minimized, and good for cornering grip
Old Sep 5, 2017 | 11:14 AM
Sipha's Avatar
Thanks, ZDan, I cant go +47 all round as Ill be using a 2" lip and a 2.5" lip. So if I go +47 in the front it will have to be +22 at the rear.
Basically I have a 6.5" and a 7" Barrel and a 2" and a 2.5" Lip so I can use them in any orientation.
Thanks !
Old Sep 5, 2017 | 11:23 AM
Site Moderator
Enh. Maybe. You'd probably be looking at -3 camber all around. Like I said neither choice is great.
Old Sep 5, 2017 | 12:03 PM
Sipha's Avatar
tire sizes would be 215/45 up front and 245/40 at the rear.
Old Sep 6, 2017 | 10:51 AM
Sipha's Avatar
So I made a mistake with the offsets !
Having had someone properly work it out for me the actual wheel sizes are:
17x8.5 +41
17x9.5 +41
How do I stand with fitment now ?
Thanks
Old Sep 7, 2017 | 08:08 AM
RedCelica's Avatar
17x8.5 +41
17x9.5 +41
Thanks
Better, but you'll still probably need to have a slight flare on the fronts. All is really gonna depend on how lowered you are.
