fitment question (already searched)
Im looking to buy rpf-1s in 17x9 +45 with 225/45 front tires and 255/40 rears. My fenders are rolled and rear bumper tabs are relocated, and i plan to buy Tein S-tech springs. I do not want to run negative camber. Would this setup work with no rubbing? Could i possibly go with a lower drop than what the S-techs offer? Thanks for any advice.
It's relative to your roll at that point...do you have a mild or aggressive roll? You could always use a caliper and measure your clearance. That would be the best determination. I personally think you would be fine, but I'm speculating.
All 4 corners have the lips rolled completely flat, but I haven't pulled them and don't plan on it.
You will be fine. But just realize that unless you get aftermarket camber correction of some sort, you will be running -camber. The lower you go, the less adjustment you will have to offset this. Dropping 2" you might be running UK spec camber alignment best case scenario. If you drop more then that your not going to be happy, -3 +
But as for clearance, no problem.
