Fitting question for 17's
Old Jun 13, 2005 | 10:20 AM
whoozbad's Avatar
Default Fitting question for 17's
Car: 2002 S2000
Set #1 (no tires yet, will prob go with stock 2004 size)
f: 17x8 offset 45
r: 17x9 offset 38
Set #2 (w/tires)
f: 17x7.5 offset 37 215/45/17
r: 17x8.5 offset 50 235/40/17
Can someone please tell me if either of these will fit without problems?
Thanks!
Old Jun 13, 2005 | 10:25 AM
koala's Avatar
Set 1 - offsets are way too low.
Set 2 - front's probably wont work well, and rears are not very close to optimal
Stock offsets are +55 front, +65 rear. Try to keep it close to that.
Old Jun 13, 2005 | 11:34 AM
SIIK2NR's Avatar
Are you dropped?
Old Jun 13, 2005 | 11:39 AM
specialque's Avatar
Even at stock height those won't work.
Set #2 is the best option, the fronts are little out of whack, but the rears will work.
Old Jun 13, 2005 | 01:45 PM
ASMspec's Avatar
If I had to choose between the two I would go with set #2. Fronts you can live with and rears are fine.
Slap on Cwest fenders and option 2 is your best friend.
Old Jun 13, 2005 | 02:13 PM
whoozbad's Avatar
Thanks for the advice folks!
I am also considering:
17x8 offset 45 all around with 215/45 front, 245/40 rear (is this the optimal tire setup?)
Car is not dropped, can I use same wheel size but different tire sizes to setup the car properly?
Also if a wheel has too low offset, can I use spacers to increase it?
Old Jun 13, 2005 | 09:27 PM
SIIK2NR's Avatar
Yes
Yes
No.... lower offsets mean it will increase the distance it will stick out. Spacers will only make it worse.
Old Jun 24, 2005 | 12:00 AM
whoozbad's Avatar
Can some share their expert opinion on fitting this set to a s2k?
17x7.5 (Front) 42mm
17x8 (rear) 44mm
215/45/17 f
245/40/17 r
Thanks!
Old Jul 10, 2005 | 06:17 PM
whoozbad's Avatar
hey guys any input on this most recent 17's attempt?
17x7.5 (Front) 42mm
17x8 (rear) 44mm
215/45/17 f
245/40/17 r
Old Jul 10, 2005 | 08:12 PM
ASMspec's Avatar
17x7.5 (Front) 42mm
17x8 (rear) 44mm
215/45/17 f
245/40/17 r
You can do the17x7.5 +42 front with a 215/45/17 tire and the rear you can go 17x8 +44 rear with a 235/40/17 and you will be fine even if you decide to lower your car. 245 you may have some rubbing issues if your dumped and if your OEM height it may stick out to the edge.
Vflow10
May 2, 2012 04:48 PM
s2tofu
19
Dec 19, 2007 01:44 AM
newspeed
May 10, 2006 12:59 PM
nmymirr
Jun 15, 2005 05:06 PM
johns2000
Feb 5, 2005 08:51 AM
