Front Tire life span? Recommendations?
Old Apr 8, 2013 | 11:36 AM
Jeremy Clarkson's Avatar
Default Front Tire life span? Recommendations?
I am looking to get some new tires because this weekend I got a bubble on the side wall of my Generals (the fronts that came with the car from a HONDA dealer no less). The rears are fine but the fronts lasted me 8k which seems very low to me. The hope is that I can get a good set of tires that will last me a little more and still handle well enough for the occasional AuotX event. I am looking at a set of RE11s but I could by swayed. So my questions to me fellow s2kers is - what kind of mileage do you get out of a front set of tires before you feel like you need to replace them? Has anyone run through an entire tread on RE11s?
Old Apr 8, 2013 | 11:54 AM
Weasel497's Avatar
My S had the factory tires on it and they lasted til I hit about 40K. Those were the Dunlop Direzza DZ101's. That was on stock suspension though. I'm lowered on coilovers with a bumpsteer kit now. I bought a new set of the DZ101's for my 17x9 square setup. and I'm noticing some toe wear on the fronts at 7K on the new tires. I expect them to last about 15-20K.
Old Apr 8, 2013 | 01:43 PM
gofast182's Avatar
With a matching set front tire life should always be double the rear. Go with the RE11's or the RE11A's.
Old Apr 8, 2013 | 01:57 PM
ungucpho's Avatar
tire life is very difficult to gauge. the life varies due to the type of driver and alignment. i was able to get about 30k on oem RE050's for the rear, the fronts were almost done, so i just swapped them out.
Old Apr 8, 2013 | 07:18 PM
RedCelica's Avatar
Dunlop ZIIs > *
Old Apr 8, 2013 | 08:31 PM
Croc's Avatar
tire life is hugely depends on car's setup and your driving style.
for me rears always last more than fronts. but not much left on t rears so i replace them all at the same time.
if i get 10,000km out of the set i'm extremely happy.
usualy it's anywhere between 6000-8000km.
i replace tires when fronts' inside became slicks. sometimes they go to the cords.
Z1 lasted 10500.
AD08 lasted 7500.
R1R lasted 6000.
Old Apr 9, 2013 | 11:20 AM
Z1 lasted 10500.
AD08 lasted 7500.
R1R lasted 6000.
How harsh are you on your tires?
Old Apr 9, 2013 | 09:52 PM
Weasel497's Avatar
I plan on flipping my tires before the insides get too bad off. Could potentially double tire life that way depending on how much camber/toe wear you're getting.
Old Apr 10, 2013 | 05:23 AM
I'm not really getting anything uneven. The outside of the fronts seems to wear a little more than the rest of the tire But I am not sure if that is due to toe being off or if it is just the way the car wears.
S2KNJ
25
Apr 11, 2014 09:00 AM
poss87
Jan 25, 2013 07:32 AM
bstarr11
Mar 14, 2010 07:56 PM
Legal Bill
Sep 5, 2007 11:36 AM
