Front tire size
Old Nov 25, 2002 | 10:47 AM
s2kbyu's Avatar
Default Front tire size
What is the maximum size tire I can put on the front OEM rims without rubiing?? Will 225/50-16's work??
Old Nov 25, 2002 | 10:49 AM
xviper's Avatar
Yes. But if you use the OEM SO2 rear tire, you've got a lot more tread than you need for the front. A non-OEM 225 has been done lots.
Old Nov 25, 2002 | 11:13 AM
s2kbyu's Avatar
I have no problem with the originals but always thought more rubber on the ground is better!
Thanks.
Old Nov 25, 2002 | 11:53 AM
Elistan's Avatar
Yes, but only if you keep the proper balance from front to rear. Otherwise you'll mess up the handling of the car by giving it too much under- or over-steer.
Old Nov 26, 2002 | 02:56 AM
jschmidt's Avatar
I've had good success with 225s on the front and more agressive negative camber on the back. In my case,
-2 degrees rear camber maintains balance while the 225s on the front greatly sharpen turn in.
Old Nov 26, 2002 | 12:22 PM
Jim@tirerack's Avatar
Former Sponsor
The 225/50R16 is the maximum width tire for the front wheels. I guess the better option would be 225/50R16 front and 245/45R16 in the rear. This way you maintain a little stagger front to rear.
Jim
albe
Jan 22, 2008 12:07 PM
johnehonda
Jun 8, 2003 03:30 PM
FLS2K
Jul 11, 2002 02:34 PM
JT-KGY
Feb 20, 2002 11:08 AM
