Help - alignment problem?
Tire shops don't always put the correct pressures into the tires
It wasn't the wind, this condition was the same throughout the entire weekend.
Is this behavior consistent with alignment one way or another?
Thanks for the
It did this equally, not favoring one side over the other. If I let go of the steering wheel, it would hold a straight course for a few moments then begin to slowly drift.
Wow, if that's the case its a bummer. Its very fatuging to drive any amount of time on the frwy because there's never more than 4-5 seconds and the steering has to be corrected. Its no fun on mtn roads either since it won't corner like before.
I bought this car new and have driven others, none has reacted like this.
Could there be ANYTHING else I should check?
If it is just new tires how long should I expect this to last? I put almost 1,000mi on them and its not getting any better.
Does everyone have this problem?
I did notice now that I'm thinking back that the inside of the fronts were worn more than the outside. Is this normal?
Sorry, I should have thought about that sooner. No, I have never had the front or rear aligned. I only have 24,000 mi total.
Balance seems fine at all speeds. They used the machine that was recommended by Jim in this forum.
I'll take it in right away to my local Honda dealer. Do you recommend doing both front and rear?
I think for a car such as this, a 4 wheel alignment is very important as each wheel is referenced with all the other wheels.
