HELP on Blitz type 01
Originally Posted by txs2knoah,Dec 22 2009, 12:55 PM
i wished i worked at a honda dealership.
ever seen honda nsx's or j's racing s2000s come in ?
Originally Posted by orangebarius,Dec 22 2009, 01:35 PM
i was thinking about buying this one here if he parts it out.
https://www.s2ki.com/forums/index.ph...ic=707201&st=0
its not worth $200 unless you sell the screws for $5 each.
ok what you should do is to contact jeff at vr wheels. the email is jdmwheels@gmail.com. i am almost positive that he will be able to help you in some way. he moves many, many authentic jdm wheels and has good connections in j-pan. i truly hope this helps you. later travis
Just measure up the bolts (length, diamter, thread pitch). Then replace all four wheels with ARP versions. If you send ARP the specifications for the bolts and nuts they will have no problem giving you equivalent or better. May not look the same as Blitz original ones.
I would not glue bolts together. Or skip out on bolts. They are what holds the rim and the centre section together.
hey dude, i got a crapload of blitz 01 rims (out of 7 only 2 are matching sizes). I'll sell u 1 rim that's got a bent barrel for a hundred bucks. You can then take off all the bolts. or i'll take all the bolts/nuts off and send them all to you for a hundred bucks shipped. I just really want to get $100 for them. I'm in florida btw. I'll take some pictures this afternoon.
I decided to not be a dick. I'll sell the bolts for $2.50 each (1 nut 1 bolt) + $5 (flat rate) shipping if anyone else wants them.
here's some pics. and if someone wants a 17x9+45 type 01 i have one for $200.
