Help Jim!!!
Old Oct 19, 2003 | 10:22 PM
Ro_Ja Boy's Avatar
Default Help Jim!!!
Is there any rubbing issues with:
18x8 5x114.3 +45 (I think) in the front and
18x9 5x114.3 +40 in the rear
All four on 235/40 tires?
They are the Ro_Ja formula 7 wheels btw thanks!
Old Oct 20, 2003 | 11:24 AM
Ro_Ja Boy's Avatar
ttt
Old Oct 21, 2003 | 12:17 PM
Ro_Ja Boy's Avatar
where are you Jim?
Old Oct 21, 2003 | 07:23 PM
MrForgetable's Avatar
All I can tell you is that your cars handling will be way off with no staggering.
Old Oct 21, 2003 | 09:52 PM
Ro_Ja Boy's Avatar
Sorry, what do you mean by this? Why would is cause that? Thanks!
Old Oct 23, 2003 | 12:37 PM
Ro_Ja Boy's Avatar
I am not positive of the offsets. The ones that are closest to the s2ks requirements. JIM?
Old Oct 24, 2003 | 10:31 AM
Jim@tirerack's Avatar
Former Sponsor
First off a 40mm offset is going to stick out and rub on the fender. Secondly the car is set up to have a wider rear tire. Handling is optimal when it is kept this way. If you run the same size all the way around on this car you will have more oversteer.
Jim
Old Oct 25, 2003 | 04:26 PM
Batbite's Avatar
You are going to RUB....LIKE A MO-FO........if you go to a 8" front and a 9" rear..........you really need to have the correct off-sets.
Mid 60's in the rear......and very high 40's to mid 50's in the fronts.......
lapulapu009
Dec 3, 2012 01:44 PM
blackfx35
Apr 27, 2006 12:56 PM
anjcohen
Dec 12, 2004 04:26 AM
T S2K H
May 7, 2004 12:04 AM
Nole99
Jun 10, 2003 08:17 AM
