Help me choose a wide wheel and tire combo
I'm finishing up a 2JZ swap in my car and need a lot more rubber out back to compensate. What wheels and tires would you guys recommend for me to run a 275 or 285 even rear tire? I'm referring to tire size more than brand. What wheels will clear the calipers and are still relatively light? Should I just use the minimum offset mentioned in the guide? Thanks for any advice, what you guys recommend is probably what I'll end up with.
jlangton
Jan 29, 2003 11:46 AM
