Help me PLEASE ... with Alignment
hi everybody i have a 2005 gpw s2000 with tein coilovers dunlop direzza tires , front cusco sway bar EDFC , i just alignment with uk SPEC i have the rear tires new and the front ones like 60 % of life. the four tires are at 30 PSI but NOW i feel the steeting more nimble or faster so much that when i change of line i feel steering much faster than before but more nervous. i feel the car nervous when changing lines after 60 or 80 km , i read that to much caster make the steering slower i was having 7 of caster and now 6 45 maybe i need to put 7 again.
Maybe i need more caster ....!!!!
UK Alignment Specs
front castor 6.45
front camber -1.0
front toe 0.0
rear camber -2.0 NOTE i put 1.6 of camber
rear toe 0.20 total 0.40
Front Caster 6o45" = 6.75°
Front Camber -1.0°
Front Toe 0.0°
Rear Camber -2.0°
Rear Toe 0°20" = +0.16°
Total Toe 0°40" = +0.32°
UK Alignment Specs
front castor 6.45
front camber -1.0
front toe 0.0
Front Camber -1.0°
Front Toe 0.0°
Rear Camber -2.0°
the car was having 0.10 from the rear left and 0.60 from the right of toe in now is corrected to 0.40 , my car when i turn the steering to fast it UNDERSTEERS also understeers on turns...
i just readed that more caster makes steering slower and more precise maybe i need more camber and caster in the front
http://desmond.imageshack.us/Himg641...pg&res=landing
if initial turn in is too quick and the car is "darty" and likes to wander RedCelica is dead on. for DD i dont know why you would want to toe it out anywhere near that much anyways...
you also stated the car understeers badly on a quick transition? thats odd if its darty as well. exactly what dunlops are you on? size? model?
lop direzza dz101 front 215 and rear 255 rim 17 size 45... i make a new alignment , it appears that it trhows off the front camber one tire was making 0.4 and the other 1.6 of camber ... the car is lowered !!!! camber kit !!!! what do you think
your choices of tire size are certainly not helping an understeer concern. if your camber is that far off there is no telling where everything else is at. fix that, and some big sticker meat up front and i bet its a new animal.
s2kwhitepanama
Apr 21, 2012 06:45 AM
