Help please 17x8 rims for front?
Ok, i am overseas and the search function will not work for some reason!!! I have to make a desicion by tomorrow and was wanting to know if anyone is running a 17x8 +40 front rim. If so what did you have to do to make it not rub? Will camber and rolling the fenders be enough or will i have to get wider front fenders???
Thanks Fadi |
silentdancer is runnin 17x8 +40 in the front with no problems all u need is a little camber! u dont really need fender mods.
k thanks!
Mine are 17x8 +42 up front :shrug: I am running -2
I'm running 17x9 +44 up front and have rolled/pulled fenders with 1.5deg of camber....I had stock fenders before and didn't rub....it depends on what size tires you get and how low you are also
i was thinking of a 225 or 235 if possable. I have tein coilovers, so i can adjust height...but i was thinking of about an 1" drop.
Would a 235 work or should i get smaller? i want a 235 bc i will be running a 17x10 rim and 275 or 285 tire on the rear and didnt want something too skinny on the front. Thanks for all the help guys Fadi |
anyone???
The 235 would be too tall. Just stay with the 225/45R17 in the front.
