Help with tire size
Old Jan 20, 2008 | 07:56 PM
Carl_S2K's Avatar
Default Help with tire size
I need help here people.
I found the wheel that i want, they're SSR Type C RS.
Front are 17x8 with +48mm offset.
Rear are 17x9.5 with +65mm offset.
Now the problem start here.I want to put 225/45R17 in the front and 255/40R17 in the back.After a little search, it seems like i will have rubbing problem in the front.
I will drop the car, maybe 1.5 inch, nothing more.
So can I go with the setup that i mention are is there a better one?
Thanks
Carl
http://www.tirerack.com/wheels/WheelCloseU...00&autoModClar=
Old Jan 20, 2008 | 08:15 PM
hk_s2k's Avatar
it's +65 offset...
Old Jan 20, 2008 | 10:48 PM
SpeedxRacer's Avatar
Originally Posted by hk_s2k,Jan 20 2008, 09:15 PM
it's +65 offset...
He is asking about the front not the rear... read the post.
I have ran those offsets and tire size before and have not had a issue. There is so many factors that will tell if you rub or not... camber, tire used, spring rates etc etc.
It is hard to tell if it will rub just by the wheel and tire specs alone.
Old Jan 20, 2008 | 11:22 PM
hk_s2k's Avatar
when he first posted, he wasn't sure if the offset in the rear was +/- , so i just answered his question. notice i posted before he edited his post @ 9:18, thx
Old Jan 21, 2008 | 12:23 PM
Carl_S2K's Avatar
He's right on that, i edit my post after his answer.
Old Jan 21, 2008 | 12:32 PM
Carl_S2K's Avatar
So the wheel/tire setup do fit, but now i need to find the right suspension setup to go with the wheel/tire setup.
What do you Suggest?
I'm new to suspension setup and everything.
I know what camber, toe in toe out, caster, spring rate mean, but i just can't figure what to go with.
All i know, is that i want 1 inch to 1.5 inch drop, nothing more.Oh i forgot, no rubbing
Old Jan 21, 2008 | 10:04 PM
s2000Junky's Avatar
Excellent performing road hugging specs for you, my personal custom set up.
camber F/-1.5 R/-2.25
tow F/ 0 R/+4
caster +6.5
I am lowered about 2.5" but you can get same spec with more conservative drop
Old Jan 22, 2008 | 09:56 AM
Carl_S2K's Avatar
I'm going with Tein Flex, well i think i am.What do you guys think about those coil over?
S2000Junky, thanks for the setup.
Old Jan 22, 2008 | 11:10 AM
s2000Junky's Avatar
Sure no prob.
I run the Buddy Club race spec. Very good choice. They have allot of strong points over coilovers in the same price range. Ajustabilty range and ease of hight control is just a few.
nemesis2k
Jan 22, 2009 07:36 AM
Carl_S2K
Feb 5, 2008 04:35 AM
RoaringVtec
Jun 7, 2005 02:56 PM
Mutlu
Mar 15, 2004 02:00 PM
dohc
Sep 10, 2003 09:27 AM
