8" width rim, biggest size tire on it?
Old Jun 3, 2005 | 01:14 PM
RoaringVtec's Avatar
Default 8" width rim, biggest size tire on it?
As described on title, what's the biggest widest tire i could fit on an 17x8 wheel, and can i put the same size rim 17x8 and use a 215 tire up front? I wanted to use 245 in back and 215, original size tires but with this rim 17x8, what offset is needed.
Old Jun 3, 2005 | 04:55 PM
JSR_AP2's Avatar
You can squeeze a 255 tire on the 17x8, but you'll need a higher offset for that. 245 will be non prob. Look for at least +50 (+55 better) offset.
Old Jun 7, 2005 | 10:37 AM
Will 18x8 wheels affect the car's handling, considering i keep the same size tires 215 front and 245 maybe 255 in the back?, what offset do you think will be best, i was looking at teh Axis Supermesh wheels. Thanks
Old Jun 7, 2005 | 12:32 PM
Jim@tirerack's Avatar
Former Sponsor
For the 17X8 rear as long as the offset is 48mm and up would be good with the 245/40R17. FOr the 255/40R17 I would look for at least a 55mm offset.
If I can help let me know.
Old Jun 7, 2005 | 02:56 PM
Jim i've read alot here about people getting the SSP SP1's from tire rack but i can't seem to find those wheels on the site. One more question, i was looking into Axis supermesh wheels, they're 18x8, i wanted to run the stock tire size 215/45 adn 245/40 in the rear, would this be ok, would the 18" wheel affect handling? Thanks
RoosterS2K
Aug 25, 2010 03:36 PM
nemesis2k
Jan 22, 2009 07:36 AM
s2kv
Oct 31, 2007 12:11 PM
dmw16
Oct 4, 2006 06:23 AM
tunerjetta29
Apr 25, 2005 09:58 AM
