Help: Would 18x9"+80 offset work in the rear?
Hey Guys,
Would you know if the rear would work in this fitament:
Work Meister S2R - The width is 18x8 with +.51 for the front and 18x9 with +.80 offset in the back
Much appreciated.
Will
Much appreciated.
Will
I agree... You may need more brake clearance.
From the hub to the end of the wheel would only be 1.35 inches, and 7.65 the other way!
Why would you want to do +80! I think it wouldn't look right, you wheels would be waaaayyyy to in.
Will, with such a high offset you can fit a 18x10.5 in there. Normal offset for a 10" wide rim is +73. For a 18x9 I would personally do a +35-+50 depending on the amount of camber you want to run and how low you're gonna set up you car. I am currently running a +34 on my 18x9 with 2 degree camber and rolled fenders on 1.75 inch drop. - could go lower however. Goodluck
Originally Posted by rijowysock,Aug 26 2006, 01:46 PM
never heard of +80
what wwheels?
what wwheels?
I dont think it would work either? Is there a way to visually measure the offset without mounting the wheels onto the car?
But I believe they should have a offset stamp somewhere on the wheels if they are Work made correct?
willfong ill do the math for you.. gimme a few seconds.ima edit this in 5
wrs2k had 10.5+74 which is 207.35mm inward from hub on 285
9+80= 194.30mm inward from hub
they wont hit suspension arms but the front edge will be comparitive of a well itl be sunk in like no other..
if 9+62 fits great these are 18mm further in on the rears
this is one case of someone hearing "higher is better" and going for the highest offset made
highest offset made from work in meister s2r 9" wide is 9+63
highest offset made in 9.5 is +69
highest in 10 is +76
your seller isnt sure what hes got.. the highest s2r's could possibly be is above
offset is marked on sticker as well as stamped on back of spoke
must be smoking crack.. oh well some do that at times.. play along w/ the +80 and be like YOOOO +80's dont fit ANYTHING ill take em off ur hands for 85$ tho just so u can free up some room. ;-)
goodluck w/ purchase we want pics ASAP
