I need some help on tire size!
Old Jun 15, 2015 | 11:35 AM
Silvers2kdaily's Avatar
Default I need some help on tire size!
Enkei rpf1s I need to know a tire size for my rims for best fitment
Old Jun 15, 2015 | 11:36 AM
17x8 + 45 offset for the front and 17x9 +45 for the rear
Old Jun 15, 2015 | 11:37 AM
s2000Junky's Avatar
Depends on if your fenders are rolled or not. If not, 215/245. If they are, then 225/45 or 235/40 for up front and 255/40 for rear.
Old Jun 15, 2015 | 11:45 AM
They're not so 215/245?
Old Jun 15, 2015 | 09:44 PM
s2000Junky's Avatar
If you don't have plans to roll them, then yes. You may need to add some negative camber all the way around depending on where your sitting now as well. -1.5 up front and -2 in back should be sufficient.
Old Jun 15, 2015 | 09:47 PM
1nate7's Avatar
If you are lowered at all, now or possibly in the future, then you are going to rub regardless of tire size. I'd go 225/45, 255/40 and roll your fenders.
Old Jun 16, 2015 | 03:38 PM
Jim@tirerack's Avatar
Former Sponsor
Without a fender lip roll I would go 215/45R17 and 245/40R17. Even then you may need some negative camber. If I can help with the tires let me know.
Old Jun 17, 2015 | 12:30 PM
Manga_Spawn's Avatar
Site Moderator
^This. Those wheel specs require a roll even with the smaller tire. Roll the fenders.
Old Jun 17, 2015 | 09:13 PM
s2000Junky's Avatar
These wheel/tire specs we seem to have a different opinion on. And there is one or two variables that could allow them to possibly rub, but its totally possible to set the car up so it doesn't. If for what ever reason someone doesn't want to dig into the fenders and risk a poor roll job or cracked paint etc, I wouldn't turn someone away from this package option.
jWESTFOO
May 17, 2014 07:03 AM
Trent06
Oct 27, 2010 02:03 PM
RedSunS2K
Jun 9, 2010 06:47 AM
stickman
Feb 16, 2008 04:14 PM
JrodsS2000
May 16, 2007 03:40 PM
