The lightest rims available for the s2000
Old May 2, 2003 | 02:14 PM
jimbo69ny's Avatar
This is an on going list of the lightest 17" rims available for our s2000.
I do not have the ability to post pictures. So if someone can post pics they are welcome to contribute.
If something is incorrect or if I am missing something feel free to correct me
lightest 17" wheels available for the s2000.
For reference the stock wheels are
16 x 6.5-------17.5 lbs
16 x 7.5-------18.6 lbs
1. Buddy Club QF P1
17 x 7.5-----12.9 lbs
17 x 8-------13.6 lbs
17 x 9-------14.5 lbs
2. SSR Type C
17 x 7.5-----13.0 lbs
17 x 8-------14.3 lbs
17 x 8.5-----15.3 lbs
3. Racing Hart CP035
17 x 7.5-----13 lbs
17 x 8.5-----14.4 lbs
17 x 9-------15 lbs
4. Volk Racing CE28n
17 x 7.5-----13.8 lbs
17 x 9-------14.8 lbs
5. Mugen MF10
17 x 7.5-----14 lbs
17 x 8.5-----16 lbs
6. Volk Racing TE37
17 x 7.5-----15 lbs
7. SSR GT1
17 x 7-------16.5 lbs
17 x 7.5-----17.5 lbs
17 x 8-------17.8 lbs
Old May 2, 2003 | 02:17 PM
RoBD305's Avatar
Try Velox, I read somewhere they are around 12 lbs. I also read somewhere about a new Enkei wheel that is supposed to be super light. Just know they exist but I can't say anything about quality and strength.
Old May 2, 2003 | 02:18 PM
mbitton's Avatar
What kinda of offset is needed for the s2000?
Old May 2, 2003 | 02:38 PM
S2-Raw's Avatar
The new Centerline Impulse is 11 lbs.
Old May 2, 2003 | 03:03 PM
Russ's Avatar
The impulse is a 17 x 7 wheel with a 42 offset and weighs 11.5-lbs. Not a good wheel for the S2000 since it does not come in a wider width in the 17-inch size.
The Velox wheel has a low offset (ET40-42 I believe) and again, is not wide enough for a staggered approach to the S2000. You could probably get away with a 205/45/17 front and 225/45/17 rear for either of the above wheels if you're basically a cruiser and not hard core corner carver (or better, a very experienced sportscar driver).
Also, the SSR GT1 17 x7 appears to only have an offset of 32 though this list might be incomplete.
http://wheelspecs.com/specs/wheelmodels/371
Old May 2, 2003 | 03:32 PM
fltsfshr's Avatar
can someone translate the value of an 11 pound stock wheel to say an 18 pound wheel of the same diameter? Is there a formula that expresses an ideal conditition gain? Is it strictly a weight thing or are there other factors that make one better than the other and in what way?
thanks
fltsfshr
Old May 2, 2003 | 05:06 PM
Russ's Avatar
figure 2.5x unsprung weight compared to static weight. All else being equal, going from an 18-lb wheel to an 11-lb wheel would result in 7 x 4 x 2.5 or 70-lbs of weight. In a 1/4-mile that would probably net you a drop in time of just over .1 seconds.
Old May 2, 2003 | 07:08 PM
s2ka's Avatar
Anybody know if Centerline has the proper fitment for the S2000? Those wheels look nice.
Old May 2, 2003 | 07:13 PM
integrate's Avatar
Spoon or Regamasters.
Old May 2, 2003 | 10:52 PM
KaliTurbo's Avatar
try out racing hart and volks, forged and hella light, I think the te37's are like 11lbs for 16" I think racing hart makes one thats even lighter than the te37's.
