lil help
Old Jan 14, 2004 | 08:03 AM
iceple's Avatar
Default lil help
I am planning to get CE28N Bronze 18x7.5(50+) 18x8.5(47+) Planning to run 225 40 front and rear 255 35.I am not planning to low my S at all(maybe Yellow Koni)put it in the second(1/2 lower all the way around).Does the CE28n come with right off set for the S2000?I know not alots of wheel out there come with the right for the S...How about the LM BBS ?Does it come with the
right offset for the S?
I also planning to have Wilwood 6piston behind it.It require 30mm spacer.Can anyone explain to me,what does spacer do
and it save to have on my car?
Thanks,
Old Jan 14, 2004 | 01:52 PM
Jim@tirerack's Avatar
Former Sponsor
An 18X8.5 wheel with a 47mm offset will not fit in the wheel well without rubbing especially with a 255/35R18 tire.
Jim
Old Jan 14, 2004 | 02:45 PM
iceple's Avatar
Thanks Jim,
What about 18x8 255/35R 18 tire?The front should be ok?
Do u guy carry any LM BBS and the right off set Jim?
Old Jan 15, 2004 | 01:29 PM
Former Sponsor
I think the BBS LM wheel will be OK in the 17" but the 18" is a 18X9.5 ET55 rear and that would be a stretch. It is the only thing they have for the car. You would need to roll the rear fender and probably run more negative camber.
You will need at least an 18X8.5 to run the 255/35R18 tires on the car.
Jim
mtl_s2k
Mar 27, 2013 06:13 PM
blackbndt
Jan 17, 2012 10:23 AM
xyster
Jun 11, 2007 09:23 PM
autophiliac
Apr 20, 2006 07:02 PM
Casas
Jul 8, 2003 06:19 PM
