Longer studs needed
Discussion about wheels and tires for the S2000.
Longer studs needed
Aug 5, 2009 | 09:38 PM
Suzuka_Joe
Nov 2004
Oklahoma
Longer studs needed
To make ssr comps 18x8 +48 in the front fit spoon monoblock calipers i read you need a 3mm spacer.
Do i need longer studs for a 3mm spacer to be safe?
Suzuka_Joe
Find More Posts by Suzuka_Joe
Aug 5, 2009 | 09:44 PM
Suzuka_Joe
Nov 2004
Oklahoma
i did another search and found where someone said a 3mm spacer makes the 18x8 +48 comps fit spoon calipers.
Suzuka_Joe
Aug 5, 2009 | 10:07 PM
s2k dre
Jul 2006
orlando,fl
U dont need studs. Just make sure u have like 7-9 full turns on the lugs.
s2k dre
Find More Posts by s2k dre
Aug 6, 2009 | 05:37 AM
1nate7
Feb 2005
Tucson
You will only lose 2 lug turns with a 3mm spacer, you should be fine.
1nate7
Find More Posts by 1nate7
17x8 +35 regamasters with spoon calipers
Dwayne_Fa5ias2k
03:50 PM
spoon caliper question
OTL
May 12, 2010
03:15 PM
Spoon calipers?
irev9k
Oct 14, 2008
09:40 PM
2006 wheels - spoon calipers - 15mm spacers?
sean2sean
May 13, 2007
11:55 PM
*** Tech Help: Spoon Calipers and Wheel Offsets.
OneQuickS2K
03:20 AM
Back to Subforum
View Next Unread
Kyowa Rims Help
10:04 PM
