low offset volk te-37 possible on s2k?
Old Jul 5, 2006 | 12:15 AM
happypuppy's Avatar
Default low offset volk te-37 possible on s2k?
just received a set of 18" te-37s with these specs on the sticker:
SIZE 18 x 7.5 J
PCD 100 OF. +30 5H CR
i searched the forums and found that high offsets are required for the s2k, but was wondering if it is possible to mount my te-37s onto my s2k? If so, what exactly will the low offset do to the car's appearance/handling? Any help will do. thanks guys.
Old Jul 5, 2006 | 01:00 AM
Project22a's Avatar
it's not even the right bolt pattern; so no, it won't fit. (and even if it was the correct pattern, that's too low of an offset)
Old Jul 5, 2006 | 07:08 AM
xviper's Avatar
Read this and you'll see why those aren't even close:
https://www.s2ki.com/forums/index.ph...&f=56&t=342793
Then you may not be a "happypuppy" anymore.
Old Jul 5, 2006 | 08:37 AM
Jim@tirerack's Avatar
Former Sponsor
If the wheel actually had the correct bolt pattern the offset would make the tires rub on the fenders. Also running the smae wheels and tires on all four corners is not a good idea on this car.
Send the wheels back and get a wheel to fit the car.
If I can help let me know.
Old Jul 5, 2006 | 03:08 PM
happypuppy's Avatar
thanks for the replies. I read through the fitment guide with the different offsets for the front and rear, but I'm still not too sure exactly what I should be getting. i'm looking into the te37s or ce28n, what ideal offset would anyone recommend for these wheels? i was thinking 17x7.5 front, 17x8.5 rear? Any recommendations or help for the offsets will do. thanks
Old Jul 5, 2006 | 05:51 PM
04RioS2k's Avatar
Steve at evolution can get you perfect volk fitment such as 17x7.5 49+ and 17x9 63 rear....you can check his thread here.....
https://www.s2ki.com/forums/index.php?showtopic=358329
Ape-x
May 25, 2010 12:34 AM
r_duff
Jul 14, 2003 11:29 AM
AUDIdriver
May 26, 2003 02:03 AM
lilbrownboy
May 13, 2003 08:53 AM
whiteGoKart39
Dec 26, 2002 07:46 PM
