lowered and offset?
Old May 22, 2006 | 01:44 AM
Enthralled's Avatar
Default lowered and offset?
was thinking about getting some 18" on my car 18x8 front 18x9.5 rear and was wondering if being lowered had anything to do with what type of offset you get?any info would be great.thanks
p.s. I'm lowered on some H&R ajustables about a finger gap all around
Peace
David
Old May 22, 2006 | 05:33 AM
Jim@tirerack's Avatar
Former Sponsor
The width and the offset of the wheels as well as the width of the tires all have something to do with it. Even your alignment settings after the car is lowered will determine if it is going to rub.
To answer your question, the higher the offset the better.
If I can help with the package let me know.
Old May 27, 2006 | 12:53 AM
Enthralled's Avatar
will 18x8 +49 ,18x9.5 +55 work or should i get something like 18x8+54,18x9.5+62
Peace
David
Old May 27, 2006 | 04:29 AM
[AP2-2NV]'s Avatar
Peace
David
definately go for the 18x8+54, and 18x9.5+62. other offsets are too low.
Old May 28, 2006 | 06:40 PM
Hot.Damn's Avatar
Originally Posted by [AP2-2NV
,May 27 2006, 04:29 AM] definately go for the 18x8+54, and 18x9.5+62. other offsets are too low.
I concur
Old Jun 2, 2006 | 07:46 AM
Luke530's Avatar
18x8 +49
18x9.5 +55
works fine - why too low? BBS and SSR both had the same offsets on their 18s, people run the with a drop just fine. Camber may need to be tweaked a little, but they look great - very flsuh with the fender, gives a very aggressive look, and does not stick out past the fender at all, still remains tucked.
Old Jun 2, 2006 | 11:34 PM
[AP2-2NV]'s Avatar
Originally Posted by Luke530,Jun 2 2006, 07:46 AM
18x8 +49
18x9.5 +55
that setup would require some negative camber. there's only about 18mm or so to spare on each side both front and rear, both the front and the rear on that setup are pushed out a few mm extra. nothign a uk spec alignment wouldn't take care of tho.
nipandnips
Mar 6, 2019 04:56 AM
DFWs2k
Mar 24, 2006 05:01 AM
quocisflying
Oct 28, 2004 08:48 AM
CDUCTV
Sep 18, 2003 09:46 AM
whiteGoKart39
Apr 11, 2003 10:47 AM
