Lowering question
Old Feb 7, 2007 | 06:43 AM
Y2Ksil/red's Avatar
Default Lowering question
I am wondering if anyone knows if I will rub with the following info:
Front: 18x8, 225/40/18, offset 48
Rear: 18x9, 265/35/18, offset 55
Thanks
Old Feb 7, 2007 | 09:26 AM
stooken's Avatar
you might, offsets are a bit low. someone correct me if i'm wrong. but then again, you're only dropping it about 1 inch. wheels might stick out a bit.
Old Feb 7, 2007 | 12:13 PM
Luke530's Avatar
I'd run 255/35/18 in the rear.
you might get a little rub...
try adjusting your alignment.
camber -1.0 front -2.0 rear, you should be ok
Old Feb 7, 2007 | 03:56 PM
sprix!'s Avatar
If you rolled your fenders, you should be fine with a little camber play. It is just an inch, so it isn't like you are dumping it really. I am only at stock height, but I never rub on 265-35-18, 9.5 width, +55 offset, and stock alignment. I did a bit of work on the fenders and everything was fine. Once you do it, let us know.
Old Feb 7, 2007 | 06:47 PM
FISH22's Avatar
on my 03 i had 17 by 7 1/2(215's), and 17 by 8(245's). offsets were +48 front, and +45 rear. i was lowered on eibachs, with no fender rolling and no camber adjustment. i never rubbed, except for one time, which it was an extremely large dig in a turn. but it took a lot for it to rub front and back. i would say, with a 265 you are going to rub for sure. with a 255, you definitley lower your chances. good luck
Old Feb 9, 2007 | 02:39 PM
Y2Ksil/red's Avatar
Anyone with the same tire/wheel sizes?? Looking for more info before I order the Eibachs...
Old Feb 11, 2007 | 03:30 PM
kentarou's Avatar
I used to have the pro kit on stock shocks...
Looks pretty nice...
Old Feb 11, 2007 | 03:36 PM
silentdancer's Avatar
your front might rub on hard turns/dips, i would stay with 255 in the rear
Old Feb 11, 2007 | 06:31 PM
Y2Ksil/red's Avatar
Already running the 265's in the rear. I know I may need to drop to 255 but the 265's only have about 8,000 miles on them. I may try it with the current tires and see what happens....
Old Feb 12, 2007 | 06:27 AM
sprix!'s Avatar
I have the same sizes, but not lowered yet. Just do it, so we can all find out what happens... I am curious to know.
