Lowering Springs
Old Dec 17, 2012 | 06:29 PM
Honda2k3's Avatar
Default Lowering Springs
Sup guys! I'm new here on s2ki from Pacific Northwest. I just bought a 17" Enkei RPF1 17x8f +45 offset (225/45) and 17x9 +45 (245/40) on a ap1, I'm currently running stock suspension the wheel gap is about 2 1/2 fingers in the front and 3 in the rear. ,I would like to drop it 1" or so (Tein S or Swift Sport)any advice to which springs is best for stock shocks? Also, NO fender work is prefer.
I live in Seattle, a lot of bumps and hills I don't want to be slammed or hellaflush. Thanks guys.
Old Dec 17, 2012 | 06:34 PM
xyster's Avatar
I had Tein S on mine (same setup) no issues.
Old Dec 17, 2012 | 07:27 PM
Honda2k3's Avatar
no rubbing or fender work? any chance you got a side shot? Thanks bro!
Old Dec 18, 2012 | 08:08 AM
GT Motoring's Avatar
Former Sponsor
Swift Spec R is what we usually recommend
Old Dec 18, 2012 | 08:47 AM
s2000Junky's Avatar
Eibach pro kit has their coil firmness set pretty optimum for stock shocks. 20% stiffer with a strait rate design, so its more noticeable improvement in response in turning transitions, wile being strait rate it doesn’t over tax the shocks like some progressive wounds springs will at similar spring weight. I think that is the thought behind it anyway. Drop coils are going to be compromised no matter what, but I felt these were a pretty good compliment in handling wile removing half of the wheel gap. No complaints. But still don’t expect to be on these for more then a year or two before your rear end starts getting bouncy. I don’t know how many miles you have on your eom shocks now, but they wont last forever.
Old Dec 18, 2012 | 09:14 AM
importrule's Avatar
swift sport mach or spec r. either would be good for stock shocks. i've had sport mach for 50k miles on one set of stock shocks, and the spec r for another 50k miles on another set of stock shocks...
Old Dec 18, 2012 | 10:14 AM
Angelfire's Avatar
what do you guys think about the espelir ASD's? seen a couple cars with em' and it gives a nice drop.
Old Dec 18, 2012 | 10:59 AM
s2000Junky's Avatar
The more you drop on factory shocks, the less able they are to cope with damping duty and the quicker they will blow out, just fyi for guys looking to exceed-1" and add any safe level of performance. If your into parking lots, then by all means, just cut your factory springs.
Old Dec 18, 2012 | 12:25 PM
importrule's Avatar
to the OP, if you do end up getting swift sport mach.... don't get CR shocks for them,... as they were designed for the stock shocks, not the CR shocks.
Old Dec 18, 2012 | 02:44 PM
Honda2k3's Avatar
thanks for the input guys! I think imma go with Swift Sport not to aggressive drop. Post your car if you lowered on Swift Sport. Thanks
