Max tire width?
Old Aug 4, 2009 | 07:31 PM
CKit's Avatar
Why didn't you just ask about putting a 225 in the front, then?
It's very common. It drives fine.
Old Aug 4, 2009 | 07:34 PM
drexelmech's Avatar
well because if a 235 would fit fine, i would really like to go with a 235/255 setup and a thicker sway bar upfront, but i feel 235 would be slightly too much on the front rims
Old Aug 4, 2009 | 08:17 PM
Moddiction's Avatar
Former Sponsor
Stick with a 225/255 setup. Going with a wider front tire actually gives you less extra grip in the rear and does not help reduce oversteer. Go with 225/255 and get a Saner or whiteline front sway bar if you want to reduce oversteer.
Old Aug 4, 2009 | 08:24 PM
drexelmech's Avatar
yes, the 235 front tire would increase oversteer, thats why i would go with a thicker front sway bar to decrease oversteer to allow for better braking while cornering and again better traction through the turn
Old Aug 4, 2009 | 08:27 PM
Moddiction's Avatar
Former Sponsor
To keep the balance of the car you should stick with 225/255 but if your set on a wider front tire go for it.
Old Aug 5, 2009 | 01:25 AM
iam7head's Avatar
tire and wheel goes together like hand and glove
you can stuff in bigger tires into a narrow wheel or stretch a narrow tire onto a wider wheel, it will degrade your handling/feel/safety. The tire contact patch will change and you'll get different feedback at the steering wheel by it
if you stuff a tire too wide for the wheel, you are most likely to get a mushy feeling, the added rubber sidewall delays the command from the steering wheel to actual turning of the rubber.
225 sounds like a safe bet, plus most performance tires today are underrated for it's width, it's a cheap way to get more "sticky" without compromising the wear and rating.
Old Aug 5, 2009 | 06:56 AM
GT Motoring's Avatar
Former Sponsor
see the above comments of iam7head. just about what i was going to say.
B.Money
Mar 23, 2012 01:29 PM
S2005x
Jun 26, 2007 08:25 PM
viets2k
Feb 8, 2007 10:57 AM
Formula
Jun 13, 2005 06:34 AM
rastamansar
Jul 28, 2004 11:28 AM
