milling down RPF1
Old Feb 24, 2015 | 06:29 PM
mcsinc's Avatar
Default milling down RPF1
Has anyone tried this to get a better fitment? Is there enough material there to get another 5-10mm +offset?
Old Feb 25, 2015 | 09:26 AM
s2000Junky's Avatar
I doubt it.
Old Feb 25, 2015 | 10:16 AM
Manga_Spawn's Avatar
Site Moderator
These come in plenty of sizes. Why do you need to mill them down? What offset are they now? Also on the concave face at least if you milled it down the wheel likely wouldn't clear the OEM brakes in the front.
Old Feb 28, 2015 | 05:19 AM
Jim@tirerack's Avatar
Former Sponsor
You would also be lowering the load capacity of the wheels. Would it be lower than what is needed? I don't know.
Old Feb 28, 2015 | 01:06 PM
949Racing's Avatar
Former Sponsor
Very bad idea. The RPF1 is a gravity cast, not pressure cast disc (center). It employs Enkei's MAT technology which is a fancy way of saying they designed it very carefully to use the minimum material mass necessary to meet load capacity, stiffness and fatigue targets. Cut into that pad and you would be seriously compromising all their careful work. Think of a racing wheel as an airplane wing. Used as intended, they have just enough strength to do the job, eventually wear out and not an ounce of material to spare to make them lighter.
Old Mar 2, 2015 | 12:44 AM
mcsinc's Avatar
OK good to know. I saw that someone had posted something about their milled down CE28s to get the proper offset, and didn't think it was a good idea. but thought maybe it wasn't as big a deal as I thought so would ask forum members their thoughts.
Old Mar 2, 2015 | 08:44 AM
Site Moderator
Certain wheels it can be done but at best you can maybe mill 3-5mm off the back. Even then I would probably just buy wheels with a better offset from the beginning.
Feezy
Dec 6, 2013 11:15 AM
l33t
Aug 7, 2013 03:51 AM
BryanRacing
Apr 12, 2012 07:12 PM
New Concept
Feb 11, 2005 09:05 PM
vas2000
Apr 1, 2002 08:07 AM
