most neg camber........
Old Mar 17, 2009 | 12:26 AM
dopesilverstone's Avatar
Default most neg camber........
i was lookn to find out what is the max neg camber my00 can be adjusted to......thanks
Old Mar 17, 2009 | 07:38 AM
EBinVA's Avatar
the rear should be somewhere between -1.8 and -2.5, I got -2.5 in the rear on my 03.
The front probably somewhere between -1.3 and -1.8 or so. Mine is at -1.5 right now and maxed out.
Old Mar 17, 2009 | 03:39 PM
camuman's Avatar
do you guys daily drive on these camber settings? i drove on uk settings -1f -2r and the insides wore significantly faster then the outsides. just curious more then anything. i am actually going back to stock 0f -1r to prolong tire life. i dont autox.
Old Mar 17, 2009 | 03:57 PM
camuman's Avatar
Originally Posted by powerneedy,Mar 17 2009, 06:47 PM
camber doesnt wear tires out faster. its toe that killes it so if they didnt get it right bam there they go...
my teg was 3.0 all the way around if not a tad more and i drove dd for 3 year on the same street tires... granted i only had 25k in that time but the tires where still good. they were parada spec 2
but i track and auto x every chance i get
i have to respectfully disagree with you if the car was just a daily driver.
Old Mar 17, 2009 | 08:29 PM
dat boi's Avatar
powerneedy, you're right about toe settings wearing out tires faster, but if the car's a DD with excessive camber settings and doesn't see much corners, then camber will greatly affect tire wear too since the tires will be riding on the inner most edges most of the time.
Old Mar 18, 2009 | 05:34 AM
s2k dre's Avatar
Im runnin -3.5 in the rear and -3 up front and my been always wearing even, not sure who does ur alignment but mine is on point.
Old Mar 18, 2009 | 07:00 AM
camuman's Avatar
[QUOTE=s2k dre,Mar 18 2009, 08:34 AM]Im runnin -3.5 in the rear and -3 up front and my been always wearing even, not sure who does ur alignment but
Old Mar 18, 2009 | 07:52 AM
s2k dre's Avatar
everybody has a different opinion, my car with stock camber and toe settings wears my tires just like now, so i get 15k out of my tires either way with even wear, so i dont know how u guys drive ur cars but here in orlando the roads are really good. So good luck with ur stock camber settings.
Old Mar 18, 2009 | 07:58 AM
ZDan's Avatar
On my Datsun and on my S2k, camber up around -2.2 hasn't resulted in any appreciable asymmetric wear. I keep toe-in to on the low side.
Old Mar 18, 2009 | 06:42 PM
lowandsmooth's Avatar
Im completly slammed down I did an alignment on my car a week a go and Im turned positive as I can get with out a aftermarket camber kit and Im at -.7 in front and -3.0 in the back with no tire wear problems. I just bought 18x8's with 48 offset so the camber will help because Im tucking factory tire right now.
