MY07 alignment specs
Old May 1, 2007 | 06:54 AM
2004S2000's Avatar
Default MY07 alignment specs
I just had my new 07 aligned at a good shop. I told them what camber I'd like and they dialed in the rest. Can't vtec the car yet so it's hard to test the handling limits. Do these numbers look ok? I'm a little concerned with the lack of toe.
FRONT
-1.2 camber
6.4 caster
o toe
REAR
-1.8 camber
.02 toe
Thanks!
Ken
Old May 1, 2007 | 09:54 AM
Project22a's Avatar
You front is fine. You could use more toe in the rear though; it'll keep your back end in check. (If that's what you want, that is)
Old May 1, 2007 | 01:11 PM
2004S2000's Avatar
any suggestions as to how much toe?
Thanks!
Ken
Old May 1, 2007 | 01:33 PM
Project22a's Avatar
0.15 is good medium. You can go a bit higher than that if you still feel as if your back end is loose, but your rear tires will wear a bit faster.
Old May 1, 2007 | 01:37 PM
INDYMAC's Avatar
Your owners manual should have the specs for you in the technical data section. You have to interpolate minutes into degrees for the technician most of the time though. Make sure that either you, or someone of similar size is in the car during the alignment. It takes two people to do the alignment anyways, so it might as well be you. Have them align it exactly to spec, and you will be a very happy camper!
blasphemy101
Jul 12, 2011 09:05 AM
SPLNDID
Mar 14, 2010 02:19 PM
bloodzombie
Aug 6, 2009 03:43 AM
Moddiction
Mar 25, 2008 01:29 PM
bps2000
Jun 15, 2007 09:19 PM
